🎫Certificates
Web communication requires certificates to ensure safe data transfer. Even though Parametric Robot Control runs primarily in a local context, gRPC requires encryption to function.
In order to trust the certificate embedded in the server (PRCServerCertificate.pfx for Windows with a validity of 30 years, PRCServerCertificate_macOS.pfx for macOS with a maximum of 2 years validity) a root certificate needs to be present on every client.
Note that the most recent version of Parametric Robot Control provides a certificate that not only works on 127.0.0.1 and localhost, but also on the following IP addresses:
192.168.0.110 192.168.1.110 192.168.8.110 10.0.0.110 10.0.1.110 10.0.8.110 172.31.0.110 172.31.1.110 172.31.8.110
There should be ways to integrate your own certificates as well, contact us if you need support.
Automated Installation: Windows#
The PRCRootCertificate.crt certificate is by default installed by the installation software on Windows. You can also find it in the server directory, in Windows by default %LOCALAPPDATA%\Parametric Robot Control\PRC.Server\Certificates. To install it automatically, you can run the PRC.CertInstaller.exe file (the same file is also run after setup). It replaces older PRC root certificates with the current one, and changes nothing if the current one is already installed.
Semi-Automated Installation: macOS#
When you start the PRC.Server app, it checks whether the certificate is trusted and offers to install it for you – the macOS password dialog is the only prompt. If that does not work, you can install it manually: in the PRC.Server folder, open the Certificates subfolder in a Terminal and enter the following command to install the certificate.
Bash
security add-trusted-cert -r trustRoot -k ~/Library/Keychains/login.keychain-db ./PRCRootCertificate.crt
The same command is also available by double-clicking the CertificateInstaller_macOS.command file in the Certificates directory in the PRC.Server directory. However, your mac may prevent you from executing that command. You can simply open a Terminal window and enter bash CertificateInstaller_macOS.command
Manual Installation: Windows#
Go into the %LOCALAPPDATA%\Parametric Robot Control\PRC.Server\Certificates folder. Double-click the PRCRootCertificate.crt file, select "Install Certificate" for "Current User". Then select "Place all certificates in the following store" and choose "Trusted Root Certification Authorities".
Manual Installation: macOS#
Navigate into the Certificates folder within the PRC.Server directory. In order to access your keychain, you will need to enter your password.
This opens the Keychain, on macOS 15 in the background. Click the icon in the bar to open it.
Drag and drop the PRCRootCertificate_macOS.crt into the Certificate section of the login Keychain.
The certificate will show up with a red warning.
Double-click it and open the Trust option. Select “Always Trust”.
When you exit the window, you will need to enter your password again. If succesful, the certificate will have a blue mark. As macOS requires us to update certificates frequently, you may have to repeat the process every few updates.
Last updated 2026-10-16
