Blender - Geometry Nodes
The Blender add-on was recently released. While it can technically use all features of PRC, the goal is not to have feature-parity with Grasshopper, but to look at a Blender-relevant feature set. Your feedback is appreciated.
Download#
You can download the prc_blender.zip addon from Github via
PRC.Integrations/Blender Geometry Nodes at main · jbraumann/PRC.IntegrationsVarious integrations of Parametric Robot Control into other software packages / programming languages - jbraumann/PRC.Integrationsgithub.comPrerequisites#
Version requirements#
- Blender 5.0.0 or later. Earlier versions (4.3 and below) are not supported — the add-on uses Blender 4.4+ Geometry Nodes APIs and won’t load on older builds.
- Blender 5.2.0+ is required for the Insert Code action node, which depends on string-typed Geometry Nodes attributes that landed in 5.2. On 5.0 / 5.1 every other feature works; the Insert Code entry simply doesn’t appear in the Add menu.
- Platforms: Windows x64, Linux x64, macOS arm64, macOS x64. The bundled gRPC / protobuf wheels target CPython 3.13 (the interpreter shipped with Blender 5.x).
Other requirements#
- PRC server running on
https://127.0.0.1:5001. - The
prc_blenderadd-on installed and enabled (Edit → Preferences → Add-ons).
After enabling the add-on, the Parametric Robot Control panel appears in the 3D Viewport’s N-panel sidebar.
1. Connect to the Robot#
In the Robot Setup box (gear icon):
- Set Client ID (any stable string, default
PRC_Blender). - Pick a Driver (e.g.
KUKA KSS (KRL)). The Robot dropdown auto-filters to that brand. - Pick a Robot from the filtered list.
- (Optional) In the Tool box, set the TCP — Position (mm) and Rotation. The rotation fields adapt to the driver convention (ZYX degrees for KUKA, WPR for FANUC, RPY for NEURA, axis-angle for UR, quaternion for ABB). The Tool ID determines which dictionary slot the TCP lives at.
- Click Setup Robot.
The first run downloads the robot mesh from the server and creates A0..A6 link objects, the TCP axis-arrow marker, the Tool Empty (parented to TCP — drop your own tool geometry under this Empty and it will follow the TCP), and the PRC_Program carrier object.
After setup, identity / driver / robot / tool fields lock until you Disconnect. To change the robot model: Disconnect, edit, Setup Robot again.
2. Run the Default AXIS Motion#
The first time you connect, also click:
- Generate Geometry Node Groups — creates all PRC node groups (motion commands, helpers, modifiers, task) and stamps the starter tree on the
PRC_Programcarrier.
The starter tree is:
AXIS Move 1 ──┐
├── Join Geometry ── PTP Motion Group ── PRC Task ── Output
AXIS Move 2 ──┘AXIS Move 2 is pre-set to A1 = 45° so the simulation produces a visible sweep.
Now in the panel:
- Click Load Task from Geometry Nodes. The status line confirms the task duration. A toolpath tube appears in the viewport (white = OK, red = alarm).
- Drag the Simulation slider — the robot animates along the toolpath.
To preview a different sweep, edit the A1 / A2 / etc. inputs on the AXIS Move nodes and hit Load Task again. (Or enable Auto-simulate, see Section 9.)
3. Building Custom Programs — the Add Menu#
Inside the PRC_Program Geometry Nodes tree, press Shift + A and find the PRC submenu (kinematic icon). Sections:
| Section | What’s in it |
| Motion Commands | PRC AXIS Move, PRC PTP Move, PRC LIN Move |
| Motion Groups | PRC PTP Motion Group, PRC Cartesian Motion Group, PRC Action Group (5.2+) |
| Helpers | PRC Curve Helper, PRC Mesh Path Helper, PRC Animation Helper, PRC Grease Pencil Helper |
| Modifiers | PRC Approach Retract, PRC Orient to Point |
| Actions (5.2+ only) | PRC Insert Code |
| Task | PRC Task |
The pipeline shape is always the same:
[motion commands or helpers] → Join Geometry → [optional modifiers] → PRC Task → Output4. Motion Commands#
AXIS Move (joint-space)#
Inputs: A1..A6 (degrees), Speed (KUKA percentage). Each instance produces one joint-target waypoint.
PTP Move#
Inputs: Object (optional Empty whose world transform drives the waypoint), Position, Rotation (added on top of Object’s transform), Speed, Posture.
LIN Move#
Inputs: Object, Position, Rotation, Speed (m/s).
Pattern: drop several motion commands → Join Geometry → wrap in a Motion Group → PRC Task.
LIN_1 ──┐
LIN_2 ──┤── Join Geometry ── PRC Cartesian Motion Group ── PRC Task ── Output
LIN_3 ──┘Mix motion types by placing each batch into its own motion group, then joining the groups with plain Join Geometry before Task. Each Cartesian Motion Group / PTP Motion Group instance becomes a separate motion group in the program.
PTP MG ──┐
LIN MG ──┤── Join Geometry ── PRC Task ── Output
LIN MG ──┘Plain Join Geometry is all you need to combine multiple Motion Groups, Action Groups, or Curve Helpers — each instance is automatically tagged so the reader keeps them as separate groups in the program.
Don’t mix motion types inside a single Motion Group. APRC PTP Motion Groupmay only containAXISandPTPcommands; aPRC Cartesian Motion Groupmay only containLINcommands. The reader rejects mismatched wiring with a clear error message.
5. Helpers (point a curve / mesh / object at the helper, get a complete motion group)#
Curve Helper#
Inputs: Curve (Object), Divisions (Int, per spline), Orientation (optional Object), Speed (m/s), First as PTP (Bool), Posture (Int).
Each spline in the source curve becomes its own motion group. A 3-spline curve with Divisions=10 produces 3 motion groups of 10 waypoints each.
- First as PTP = False → N Cartesian motion groups, all LIN. One group per spline.
- First as PTP = True → For each spline, two motion groups: a PTP Motion Group containing only the first sample, then a Cartesian Motion Group with the remaining samples as LIN. A 3-spline curve emits 6 motion groups (3 PTP + 3 CP) in spline order.
Mesh Path Helper#
Inputs: Mesh (Object), Orientation (Object), Use Normal (Bool), Flip Normal (Bool), Speed, PTP (Bool), Tool ID, Posture.
Vertex order = path order. Use this for edge loops, polylines, or any mesh whose vertex ordering matters.
- Use Normal = False → orientation taken from the Orientation object’s rotation.
- Use Normal = True → orientation derived from each vertex’s normal (works on faces). Local +Z aligns to the normal; rotation around the normal is arbitrary — chain
PRC Orient to Pointafter this if you need controlled X. - PTP = True wraps in a PTP Motion Group, else Cartesian Motion Group.
- Tool ID picks which entry of the robot’s tool dictionary the resulting motion group runs with. Leave at
0to use the default tool you configured in the panel; set to a non-zero number to reference an additional tool you’ve registered on the server. - Posture only applies when PTP = True — it’s the joint-configuration code (zero-padded to 3 digits at submit time, e.g.
010) used by the PTP waypoints.
Animation Helper / Grease Pencil Helper#
Both are thin wrappers for discoverability. Point Source at the baked path mesh you create via the panel’s Animation Source / Grease Pencil Source sub-panels (see Section 8).
6. Modifiers#
Approach Retract#
Inputs: Geometry (one or more motion groups), Offset Start (m), Offset End (m).
Duplicates the first and last waypoint of each Cartesian motion group in the input, offset along world +Z. The new waypoints inherit the source point’s prc_motion_group, so they stay inside the same group — they just bracket it. PTP motion groups and Action groups in the same input pass through untouched. A 3-CP-group input gets 3 approach + 3 retract points; PTP groups in the same stream contribute zero extra waypoints.
Mixed input is therefore safe: drop a Curve Helper output (with First as PTP enabled) or a Join Geometry of mixed PTP + CP groups straight in, and only the CP segments grow approach/retract flanks.
Set either offset to 0 to disable that side. World +Z is used (rather than the per-vertex tool-Z) so orientation changes inside a single motion group don’t tilt the approach direction.
LIN moves → Join → CP Motion Group ─┐
LIN moves → Join → CP Motion Group ─┼── Join Geometry ── Approach Retract ── PRC Task
LIN moves → Join → CP Motion Group ─┘Orient to Point#
Inputs: Geometry, Target (Object), Face Away (Bool).
For every waypoint, rotates the orientation around its local +Z so local +X points at (or away from) the Target object. Useful for:
- Spray nozzles aimed at a workpiece centre.
- Welding torches whose front edge tracks the seam direction.
- Camera-on-flange setups pointing at a focal subject.
Place after motion groups; the helper preserves all other attributes.
7. Actions (Blender 5.2+)#
Insert Code#
Inputs: Code (String), Is Comment (Bool).
Drop a single inline robot-program line (KRL, RAPID, etc.) into the program flow.
... motion groups ... ─┐
├── Join ── PRC Task ── Output
PRC Insert Code ───┤For multiple consecutive inline-code instances, just join them.
8. Auxiliary Sources (collapsible panels under the main panel)#
The three sub-panels at the bottom of the main panel (collapsed by default) generate path meshes that you point your Helper nodes at, or play back without PRC.
Animation Source (ANIM icon)#
Bakes any animated Object’s motion over a frame range into a path mesh.
- Pick an animated Object (typically an Empty with keyframes).
- Set Frame Start / End / Step.
- Choose Mode: All LIN, All PTP, or First PTP, rest LIN.
- Set Speed (m/s for LIN), Tool ID, and Posture (PTP only).
- Click Bake Animation — produces
PRC_AnimPath_<name>.
In the GN tree: drop a PRC Animation Helper, point Source at PRC_AnimPath_<name>, join into Task.
Grease Pencil Source (pencil icon)#
Bakes a Grease Pencil drawing into a path mesh with tangent-derived orientations.
- Pick a Grease Pencil object.
- Set Layer Index / Frame Index.
- Optionally set Sample Distance (resample by arc length, 0 = use raw stroke points).
- Choose Orient: Tangent + World Up or Tangent + Up Object (point the Up Object slot at any object — its +Z becomes the up reference).
- Choose Mode, set Speed, Tool ID, Posture.
- Click Bake Grease Pencil — produces
PRC_GPPath_<name>.
Drop a PRC Grease Pencil Helper in the GN tree, point at the baked mesh.
Robot Animation (kinematic icon)#
Bakes the simulated robot motion into a self-contained Blender animation that plays back without PRC running.
Prerequisite: connected, with a task loaded (status line shows duration).
- Set Target Name (default
PRC_RobotAnim). If a collection of this exact name already exists, its contents are replaced; otherwise nothing in the file is touched. - Read the live label:
Duration: …s · FPS: … · Frames: …. Override FPS Override if you want a different sampling rate (0 = use scene FPS). - Set Frame Start (default 1).
- Toggle Set Scene Range to expand the scene’s playback range over the bake.
- Click Bake Robot Animation.
The resulting collection is shareable, renderable, and exportable without PRC installed.
Studio Environment (scene icon)#
Builds a symmetric, 360°-friendly product-shot studio around the robot — a cyclorama backdrop (flat floor → curved corner → vertical wall), an overhead key light, and a configurable ring of rim/fill lights. Sized off the robot’s bounding box.
Prerequisite: Setup Robot has run (so the PRC Robot collection exists).
- Set Floor Radius (multiplier on the robot’s horizontal extent) and Wall Height (multiplier on the robot’s height).
- Set Key Power (overhead light, watts), Rim Count (lights in the ring), and Rim Power (per-light watts).
- Click Build Studio Environment — produces a
PRC_Studiocollection containing the backdrop and a nestedPRC_Studio_Lightssub-collection. Re-running rebuilds cleanly.
9. Live Workflow#
Auto-simulate on Edit#
In the Task & Simulation box, toggle Auto-simulate on Edit. While on, any change to PRC_Program’s geometry (a node socket, an upstream Empty’s transform, etc.) re-submits the task to PRC after a brief debounce. Disable for big programs where the resubmit cost is noticeable; the manual Load Task button still works as a force-reload-now.
Status indicators#
Above Task & Simulation:
- Toolpath valid (green check): last task simulated cleanly.
- Toolpath has alarms (red banner): part of the path triggered an alarm.
- No toolpath loaded (dim dot): nothing submitted yet.
Disconnect#
Stops the feedback stream, resets connection state, unlocks Robot Setup / Tool fields. Existing A0..A6, TCP, Tool, and PRC_Toolpath_* objects survive — Setup Robot reuses them.
10. Example: Putting It All Together#
Goal: spray-paint along three offset polylines on a curved surface, with safe approach/retract on each pass, and a baked animation for client review.
- Setup Robot, configure your tool TCP, Setup Robot.
- Generate Geometry Node Groups.
- In the scene: a Curve object with three splines tracing the paint passes, plus an Empty whose +Z is the desired tool axis.
- Open the
PRC_ProgramGN tree and wire:
Curve (3 splines) ──► PRC Curve Helper ──► PRC Approach Retract ──► PRC Task ──► Output
Orientation Empty Offset Start = 0.05
Divisions = 30 Offset End = 0.05
Speed = 0.05
First as PTP = ☑
Posture = 10- Click Load Task. Drag the simulation slider to verify each pass.
- Toggle Auto-simulate on Edit; tweak Divisions / Speed interactively until the path looks right.
- Open the Robot Animation sub-panel, set
Target Name = paint_pass_v1, click Bake Robot Animation. - Save the .blend. The
paint_pass_v1collection is now a self-contained baked animation — render it, share it, export to glTF/Alembic, all without needing PRC running.
That’s the full workflow.
11. Notice of AI use#
This document has been generated with the use of AI.
